Hi all,
We have recently moved house, went from a flat to a semi, flat had a combi boiler, house has an older back boiler system.
It was fitted in 1998 and is a baxi system with tank in loft, cylinder in bedroom, boiler behind fire.
I have drained the system, used sludge remover, left for a week, drained & filled with a inhibitor, read how to do it on the net, fairly confident with diy stuff or i would ask a pro.
Few questions...
1) This was happening before the clean, but seems to be worse now, can hear air rushing through certain (not all) rads every now & then, why would this be?
2) When the hot water is on, the rad in bathroom & bedroom that has cylinder in heat up, why is this? Is this normal?
3) The same two rads constantly need bleeding every few days, i do this when the system is cold, but its very annoying to have to keep bleeding, i'm assuming air is getting into the system, but a) why only these two, and b) how do i diagnose?
Thanks, any additional info needed, please ask.
Mark.
