hi, can anyone please advise ??
i've got a baxi bahama 100 combi . the expansion tank was split , so i've changed it , and recharged it to the 1 bar pressure as stated in the manual .
previously , the domestic hot tap(s) flow was fair , but the water was very hot . now , the flow is fast , but the water is much cooler , even with the boiler temp set "flat-out".
i've changed the filter cartridge ( 3- way valve) and any other filters i can find , + various other bits and pieces , and still its no better .
would it help if i reduced the expansion tank bar pressure slightly ? , as
the problem only started when the tank was changed .
i would like to ( if poss) keep the boiler running for a couple of years yet ,
so any advice is welcome , except throw it in a skip ...thats plan B !!
thanks
