by plumbbob »
Mon Nov 01, 2010 8:00 pm
To be honest, the problem you already have is likely to be caused by the 10mm microbore pipe. Microbore systems have to be carefully balanced which can be quite difficult even for the experienced installer. If the small bore pipe runs are long and flow pressure is low, you will continually have problems.
Problems with microbore can be exacerbated by sludge build up often found in open vented systems.
Frankly, and this is a personal opinion, but I would avoid plastic 10mm for these reasons and especially because the 10mm pipe inserts reduce the bore to a ridiculously minuscule size!
Use 22mm for the main feeds and drop down to a 15mm feed for each radiator. 15mm can feed a pair of rads but no more.
Use copper where the pipes will be visible and either plastic or copper for to your choice elsewhere. Speedfit is fine, but to be honest, I prefer Polyplumb as the fittings are smaller.
