Block wall
len morley
Block wall
by len morley » Mon Jun 18, 2007 1:33 pm
I am building a wall approx 3m x 2.4m between two yellow stock brick walls to reinstate an old kitchen, which will then be rendered, I intend to use breeze blocks in make a double thickness wall, but there seems so many types, can you advise on what type etc :? to use please.
The wall thickness will be 200/220 mm.
thedoctor
by thedoctor » Thu Jun 21, 2007 8:45 am
What is the wall carrying, is it internal or external and does it require a cavity.
It is currently Thu Jan 30, 2025 11:21 pm
