boiler change
heps
boiler change
by heps » Wed Sep 01, 2010 4:18 pm
Hi all just a quickie how hard is it to change from a normal boiler and replace it with a combi does it involve a lot of changes and whats the cost implications ??
cheers heps
by htg engineer » Wed Sep 01, 2010 7:45 pm
It's not difficult for a gas safe engineer, as for the cost you need a RGI to come out to give a price. It all depends on pipe runs etc etc
You basically keep the flow and return to the radiators, lose the flow and return to the tank/cylinder and lose the cylinder and tanks.
You need a 22mm gas supply to the boiler, connections to hot and cold water supply, one pipe fro pressure relief discharge and then a condensate pipe.
Install entire new flue system, you need a fused spur at the boiler, then an integral, remote or wireless programmer and room thermostat.
htg
heps
one more question
by heps » Thu Sep 02, 2010 1:07 pm
Thanks for the info just one other question how do i get cold water does that mean a whole new pipe for the cold feed etc or can that be tapped into ?
thanks Heps
Alex_H
by Alex_H » Tue Oct 12, 2010 4:53 pm
I think it could be tapped into. Why should you change the pipe?
What boiler do you want to buy?
by htg engineer » Tue Oct 12, 2010 6:14 pm
You can connect in anywhere on the MCWS.
htg
