Boiler conversion
6 posts   •   Page 1 of 1
tumbleweed
Boiler conversion
by tumbleweed » Thu Nov 29, 2012 4:57 pm
Quick question..
I have a baxi boiler atm and need a new system..
Which would be cheaper converting to a combi or wood burning stove?!
Re: Boiler conversion
by htg engineer » Fri Nov 30, 2012 7:56 pm
Cheapest regarding install - will be a combi as you may be able to keep your existing radiators and pipework. Wood burning stove, you're going to need a new cylinder etc
tumbleweed
by tumbleweed » Sat Dec 01, 2012 1:02 pm
I have been informed that I may eventually have to replace the whole system cause of problems a pressure change would cause and would likely not have the same problems if converted to a wood burner?!
Do you know what firefronts are compatible with a baxi 552 boiler?! I am only thinking of changing cause the fire was broken and have tipped it.. May need a bit of time to save up as the conversion whichever one I eventually choose is going to be costly :( ..
by htg engineer » Sat Dec 01, 2012 9:08 pm
I had this query recently and couldn't find a new replacement firefront, if you could still buy them they'd be £400+. You may find a second hand one if you shop about.
tumbleweed
by tumbleweed » Sun Dec 02, 2012 11:41 am
Okay.. Thankyou.. Wish me luck :) ..
Sahins
by Sahins » Thu May 23, 2013 7:04 pm
I ave a Firefront that will met you're needs; have a look here: http://www.gumtree.com/p/for-sale/baxi- ... 1015425253
It is currently Wed Oct 14, 2026 2:40 am
