Boiler in same room as shower?
homesolutions
Post by homesolutions » Tue Jul 13, 2010 6:54 pm
Hi there, i want to put a shower in the same room as a boiler and if i put all the electrics on the wall outside this and put an extractor fan in the room will this have any affect on the boilers electrics?
Thanks for reading
eggers
Post by eggers » Wed Jul 14, 2010 8:38 pm
Hard to say, there are "zones" which dictates what electrical appliances can be fitted in relation to water utilities, particularly showers. Most boiler the electrics are protected but not water proofed.
What boiler to you have? If it's open flued appliance, it's a big no no
Post by htg engineer » Thu Jul 15, 2010 8:36 pm
If moisture gets into PCB/controls - it's going to cost you in the long-run. Could you build a cupboard for the boiler.
If not I would definately re-think boiler position.
htg
eggers
Post by eggers » Fri Jul 23, 2010 4:40 pm
htg engineer wrote:If moisture gets into PCB/controls - it's going to cost you in the long-run. Could you build a cupboard for the boiler.
htg
thats true, i find it depends on the boiler, some boilers are better then others at keeping the moisture out
