Boiler Loosing Pressure Around Half a bar Every 3 days?
Not stupid
Post by Not stupid » Fri Feb 05, 2021 5:21 pm
Hi all
My boiler, logic, is losing pressure, about half a bar every 3 days.
House is new build (10 years old) with 10mm drop plastic pipes to rads
Cant find the leak as all the pipes are in the joists so nothing visible in ceiling.
Nothing visible in the boiler
No air in rads
Open / hoping for any help or suggestions.
Re: Boiler Loosing Pressure Around Half a bar Every 3 days?
Post by stoneyboy » Sat Feb 06, 2021 10:21 pm
Hi notstupid
Either you have a leak - in which case try adding leak sealant to your system. OR your pressure vessel has failed and needs replacing. OR your pressure relief valve is faulty. Or, or ,or .... there’s probably plenty more.
