Three bedroom house with radiator c/h. Boiler Potterton RS 50/15 Well serviced each year. problem started 5 days ago, working fine up to then.
Room thermostat working normal, circulating pump cuts and heats all radiators as per normal. Above the boiler which is in kitchen is bathroom with a radiator this normally is always hot when the boiler is on, and still is, however the bedroom radiators normally stay cold unless the thermostat and circulating pump cut in, but five days ago without the thermostat or pump cutting in the bedroom radiators only are hot all the time, and consequently the boiler is coming on more often, why and how are the bedroom radiators getting hot without the thermostat or pump sending a signal? Would appreciate any suggestions. Mike Devon
