by marrtin »
Fri Dec 28, 2007 6:34 pm
The frost stat would be separate to the boiler and look similar to a room thermostat, but should be set between 3 and 6 degrees C.
If the boiler is in the garage or loft space, the stat will be close by. Follow the wires.
If none of your system is in an unheated area and therefore less prone to frost damage, then probably a frost stat is not fitted and you have a different problem.
