I turn to this forum in the hope for some help. I have trawled the internet for a solution, but no joy.
Here is the problem:
I have a Boxer C28 boiler (it is approx. 3 years old). Hot water is working fine, but I have no/limited central heating. I say no/limited because this is an intermittent problem. This boiler is very temperamental.
When the CH is not working here is what happens:
The green LED lights on the boiler control panel, meaning there is a demand for heat. The burner ignites on the boiler, as you would expect, but then goes out several seconds after the electrodes stop sparking. Then five minutes later the same thing. This behaviour will repeat over and over. However, if I leave the boiler in this condition for long enough (anywhere from a couple of hours to days), then the boiler might eventually behave itself. i.e. The burner will stay lit until the room thermostat reaches the desired temperature.
I can assure you this problem is nothing silly. i.e. timer, thermostat setting, controller setting, etc. The user controls are set correctly.
So far I have done the following:
1) Checked the system for a blockage. I have drained/flushed/refilled the system (using an additive).
2) I have bled the system, and there is no air-lock.
3) I have checked the fan and pump are running. All seem fine. In the case of the pump there is 240v on the terminal, the rotor is free, and the pump is vibrating. I can hear water running through the system.
4) I have replaced the CH sensor on the pipe from the divertor valve.
One point about item 4). If I unclip the sensor from the pipe, the burner will stay on, but the outlet pipe gets very hot.
Please can anyone advise what the problem might be? Remember, the system heats up very well on a good day - when the boiler plays ball.
Any ideas..? PCB perhaps?
