Building approval to build an internal archway
kareny
by kareny » Wed Dec 05, 2007 1:54 pm
We would like to remove some double doors which separate the living room from the dining room and put in an arch way to increase the living accommodation. Does this need planning approval. Can we do this ourselves or do we need a structural engineer before carrying out the works?
kbrownie
by kbrownie » Thu Dec 06, 2007 5:40 pm
Hi kareny,
If the wall is a load bearing/supporting wall you will not need planning permission but building controls should be notified. They will charge and inspect the work done. An engineer will need to to structual calcs, but you can do the building work yourself.
Good Luck
KB
