Can a shower pump be used for bath & shower valve?
Lal
by Lal » Sun Aug 09, 2009 10:16 pm
Hi, can a shower pump be used for a trple valve, which feeds to shower and bath?
plumbbob
by plumbbob » Mon Aug 10, 2009 9:39 pm
Really don't have a clue without any information.
One thing I can say, generally, you cannot use the same pump to supply both a shower and a bath.
Lal
Shower pump
by Lal » Tue Aug 11, 2009 7:48 pm
Hi, the water pressure is quite low. So I was wondering whether a two way valve (feeding to shower & Bath) can be connected to shower pump?
plumbbob
by plumbbob » Tue Aug 11, 2009 11:57 pm
How your water pressure can be made better depends entirely on what type of system you have and unless you are willing to post more really this topic is going nowhere. Do you expect people to guess??
What do you mean by a two way valve? A two way valve is just a normal valve where water can flow in either direction.
chris_on_tour2002
by chris_on_tour2002 » Fri Aug 14, 2009 4:44 pm
i assume that by 'two way valve' you mean some kind of manually operated diverter valve that sends the pumped water either to the bath or shower and not both simultaneously.
not aware that such a system exists and if not then probably for good reason. it IS possible to set up your system with a pump to service more than one appliance but it needs to be done with care - best to get a pro in to take a look.
It is currently Sun Aug 30, 2026 12:09 am
