[b]Adding a radiator to a room.[/b]
There is a radiator one side of the room and I want to add another the other side of the room. lifting the boards reveals 22mm pipework with 15mm leaving to feed the existing radiator.
I assume the 'Flow' side is the control side of the rad and the return is on the 'balance' valve side?.
Now I'm all for easy fit so
1. Is there a self cutting fitting available to fit to existing 22mm pipes so I can exend them without having to drain the system down [gravity fed I believe]
2. Are there plastic pushfits available for central heating?
3. Is there plastic pipe available for central heating flow and feed pipes.
I'd like a c/heating engineer do it but I'm strapped for cash and won't employ when I can't possibly pay.
