Central heating not heating up all rads
mikeharrison
by mikeharrison » Sun Oct 24, 2010 7:26 am
Just fired up my central heating and having problems with it not heating up all the rads properly. I have drained the system and refilled it and bleed all the rads. Fired up the heating and only have 1 rad upstairs which is hot the other 3 Luke warm and 1 cold upstairs and the 3 rads downstairs cold. Can't hear if there is any air left in the system so I'm stratching my head and would like any ideas of what it could be. I have a potterton neatheat 16/22 boiler
Looking forward to any help
Cheesie1
by Cheesie1 » Mon Nov 08, 2010 7:20 am
sounds like the pump has gone! if some radiators are working! After u have switched ur heating on for about five mins, feel ur pump (usually in ur a/cupboard) if it is red hot or sounds noisy it's struggling to circulate. Swap pump should be fine.
loopslike
by loopslike » Mon Nov 08, 2010 2:17 pm
I also support cheesy. It may be the possible problem of your heater. You can try just increase the heating level of the heater. If it not work call a local technician or contact with your product customer care. The will help you to solve this problem. :)
