central heating not working after new radiators fitted
pinkllama
Post by pinkllama » Thu Jan 07, 2010 3:03 am
hi all,
i have just replaced 2 radiators with larger ones in my flat as it took hours to heat the flat up.
it's an open system, ie there is a header tank in the loft.
i refilled the system and bled all the radiators.
the problem now is that the boiler fires up for a few minutes and then switches off - not heating any of the radiators.
prior to fitting the new radiators, it worked fine.
i understand that the boiler is switching itself off as a safety measure as it is too hot.
i think that there could be an air lock in the boiler that is preventing it from working/ pumping the water around the radiators.
its currently -5c outside and i desperately need some help!!
one thing that could be a clue as to why it's not working is, when i refilled the system the header tank let loads of water in for a few seconds then it just trickled in for the next hour or so before all the radiators were full of water.
any advice?
thanks
plumberman666
Post by plumberman666 » Thu Jan 07, 2010 10:50 pm
The boiler is airlocked and its a pain to shift,you need to try and vent it by slightly opening a compression fitting on top of the boiler,there should be one. You can remove the thermostat sensor and kettle the boiler but this is a bit dodgy. It seems that your system has some sludge in it. You can remove this by adding some remover and circulating it for a couple of days with the heating on,then removing it and adding some protector.
rosebery
Post by rosebery » Thu Jan 07, 2010 11:45 pm
You've also got a blockage in your microbore pipework so clearing the airlock now is prolly a waste of time. You really do need to get someone in.
pinkllama
Post by pinkllama » Fri Jan 08, 2010 4:56 am
[quote="plumberman666"]The boiler is airlocked and its a pain to shift,you need to try and vent it by slightly opening a compression fitting on top of the boiler,there should be one. You can remove the thermostat sensor and kettle the boiler but this is a bit dodgy. It seems that your system has some sludge in it. You can remove this by adding some remover and circulating it for a couple of days with the heating on,then removing it and adding some protector.[/quote]
thanks for the advice.
got a plumber round as i think i was starting to do more harm than good.
