Hi, I have what I believe is a gravity fed CH system with gas boiler downstairs in kitchen and hot water tank in bathroom with expansion tak overhead.
the hot water in taps is fine; the downstairs radiators (2 double and 1 single all hot, but upstairs - 2 double and 1 single are all cold. I have tried bleeding all upstairs radiators with the circulating pump off, the radiators get warm, then I switch system on, and after about 10 minutes they go cold again.
Now the radiator valves are leaking ! I have turned the cold water supply off to the expansion tak and drained the hot water cylinder. I am replacing radiator valves - how do I then recharge and balance system. All help greatly appreciated.
