CH Programmer with no HW facility
DAVE@ROTHERHAM
by DAVE@ROTHERHAM » Sat Jun 16, 2007 10:44 am
I have a DANFOSS 103ES CH Programmer.
My cylinder tank dosen't have an electric water heater.
To get hot water I have to have the CH on, is it possible to heat the water without heating the radiators?
The only solutions I can think of are to turn the radiators off or changing the programmer.
Can anyone suggest a better solution?
by sparx » Fri Jun 22, 2007 9:33 pm
Hi Dave may I suggest you repost ? with more info. abt system ie is it fully pumped with motorised valve(s), or Gravity fed HW tank, is there a tank thermostat & a room thermostat, what type of boiler do you have where, if fitted is circ pump? give us a clue & someone will try to help,regards SPARX
