Cleaning Pop-up Sink Waste Units
6 posts   •   Page 1 of 1
Riverman
by Riverman » Sat May 29, 2010 11:23 am
I have a new bathroom washbasin fitted with a pop-up waste plug. Cleaning is a problem, as scum and deposits build up between the "lid" and the "floor" of the outlet. I was wondering if the "lids" of these pop-up units are removable, either by unscrewing or prising off. I am reluctant to put either kind of pressure on it if it is not designed to do this. Thanks for any help.
by stoneyboy » Sun May 30, 2010 8:32 pm
Riverman,
Some bright spark came up with idea of putting a ring at the bottom of the pop-up plug so the actuating rod fitted into it. This makes the pop-up plug impossible to remove from above. Undo the actuating rod (behind the waste) partly retract the rod so you can then remove the pop-up and clean it. Refit the rod and drop in the pop-up - you will have to adjust the length so it seals again.
Riverman
by Riverman » Mon May 31, 2010 5:44 pm
Many thanks for the information. My mistake for not being clearer, as you have quite reasonably assumed I was talking about a pop-up waste controlled by a lever or knob with connecting rod. What I actually have is one of those spring-loaded jobs that works like a toggle switch. Push it down once and it's closed. Push it again, and it's open. Sorry for not making that clear.
by stoneyboy » Wed Jun 02, 2010 10:34 pm
Riverman,
With the spring loaded pop up wastes you should be able to unscrew the chrome cap and gain access to the inside of the waste.
Riverman
by Riverman » Thu Jun 03, 2010 5:57 pm
Many thanks!
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:48 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Wed Jun 17, 2026 9:46 pm
