by roger196 »
Sun Dec 16, 2007 8:23 pm
Have you tried changing the pump setting?
I am puzzled why this problem has arisen after nine years. What has changed to produce this problem?
Have any alterations been made to the system recently.
The length of time suggests that furring up of the pipes might be a possible cause, though noises are usually around the boiler area. When was the last time your system was flushed through and is there effective inhibitor in the system.
Another possible solution, for a sealed system, is to ask your plumber to fit a shock arrester to prevent water hammer. These are listed in the BES catalogue. A diy version of this is to deliberately leave some air in the radiator nearest to the noise problem. This air may act as an air cushion.
Finally noise often travels considerable distances inside walls making tracking of the source a challenge.
