Post
by rosebery »
Mon May 04, 2009 10:26 pm
You won't desludge by just draining. Even adding X400 for a a while then draining again won't shift it all. If you have a sludge problem you can either add X400, wait, drain, remove each rad in turn take it outside and mains flush it through with a hose pipe or just powerflush the system.
However, I think your immediate problem isn't sludge its air. You haven't cleared all the air out of the system on refilling.
Clear the airlocks and you'll most likely be OK.
