Cold Radiators
woodie
Cold Radiators
by woodie » Mon Nov 19, 2007 8:50 am
When I used most of the hot water ie for a bath and then the boiler comes on to re heat the water my radiators go cold. If I switch off the hot water my radiators go hot. It only seems to happen when I use a lot of hot water.
roger196
by roger196 » Mon Nov 19, 2007 7:55 pm
Your boiler is setup to give priority to hot water. Only once it has reheated the hot water tank will it turn its attention to the CH.
DONFRAMAC
by DONFRAMAC » Tue Nov 20, 2007 12:13 am
Combi boilers are designed to do just that,---- hot water priority, diverter valve returns flow to rads only after hot water demand is finished.
woodie
by woodie » Tue Nov 20, 2007 11:55 am
Thanks for info. Had system for awhile never noticed it before.
