combi fires up when cold water tap used!!!
6 posts   •   Page 1 of 1
joseph76
Post by joseph76 » Fri Aug 08, 2008 5:59 pm
Hi, my combi bioler (vailiant ectec plus)sometimes makes a noise when i used the COLD tap. the its sounds like its firing up??? ie the same noise as when the hot water tap is opened up.
any ideas
in advance thanks
Post by htg engineer » Sat Aug 09, 2008 7:31 pm
Sometimes just the flow of water through the cold water pipes is enough to push the diaphragm and operate the microswitch.
Will the flow of water pass the boiler before getting to the cold tap you're talking about
htg
Steve the gas
Post by Steve the gas » Sun Aug 10, 2008 3:39 am
Hi Joseph,
Can you confirm that it does fire up? :shock:
Steve
Post by htg engineer » Mon Aug 11, 2008 3:31 pm
Also some mixer taps and even washing machines can cause this problem, if the cold water is travelling back up the hot pipe.
Can be solved by fitting NRV's.
htg
joseph76
Post by joseph76 » Tue Aug 12, 2008 8:42 pm
[quote="Steve the gas"]Hi Joseph,
Steve[/quote]
Hi Steve,
I have downloaded the boiler instructions. it looks like it's just the pump which is operating, as this symbol lights up after operating the cold water supply. the gas light only comes on when opening up a hot water tap. so sorry i was mistaking the pump sound for the boiler firing up... doh! i take it this is normal for the pump to operate after using cold water????
joseph76
Post by joseph76 » Tue Aug 12, 2008 8:46 pm
Steve[/quote]
Hi Steve,
