I've had a Vaillant Ecotec Plus Combi boiler installed a few months ago.
Unfortunately the plumber who installed it has gone back to Poland.
The problem is that the flue drips water constantly and it is gradually soaking into the brickwork of the wall.
I've taken the end off the flue and checked the level. It slopes slightly downwards towards the outside of the house. Is this OK?
I've also put a container under the condensate outlet and I don't seem to be collecting any water in it.
Is water going down the flue instead of the condensate pipe?
If this is the case, can I just lift up the flue pipe a little to solve the problem?
Other than this the boiler is working great and the plumber seemed to do a good job on it.
