My Keston condensing boiler is approx 10 years old (fitted in house from new). It has been working fine until last year when it stopped working. Symptoms were boiler failing to fire but the water pump stayed on continually making a 'buzzing' noise. This noise does not occur when the boiler fires correctly and in normal operation the boiler fires, ignites, heats water and then stops (as does the water pump). In Jan the pressure switch failed causing water to leak from the boiler - this was fixed and the boiler worked fine for 2 months or so and then the intermittant failure began again.
The intermittant nature of this fault means that the boiler will cease to fire every few days or so. Swithing off at the mains for a long period (a day or so) and then switching back on at the mains can sometimes coax it into firing - but sometimes not; these times the 'buzzing' noise of the pump running can be heard.
Is this an easy fix - we have spent £500 on spare parts so far - new boiler would be only £700 for Keston replacement?
Could this be a pressure issue which is seperate to the boiler - and if so how would that cause the boiler to fail to fire?
Can anyone please help me before I get British Gas out - they have quoted £5K to fix replacing boiler, tank, whole schebang?!! I nearly had a heart attack!! Bang goes the new kitchen tile fund....!
