Post
by sandancer »
Thu Nov 06, 2008 12:10 pm
[quote="ericmark"]Where does it say that? I have done a search for 1.2 m and consumer unit neither with any results. However
"553.1.6 A socket-outlet on a wall or similar structure shall be mounted at a height above the floor or any working surface to minimize the risk of mechanical damage to the socket-outlet or to an associated plug and its flexible cord which might be caused during insertion, use or withdrawal of the plug."
Seems to say you can place it out of harms way. Are you sure it is not Part M rather than 17th Edition you got height restriction from?
If so type of building will make a huge difference. There are minimum heights for unlocked boxes in public places (2.5 m) and minimum heights for lights outside (2.8 m) without protection and socket height outside 0.5 to 1.5 m (caravan sites) even that is allowed to be higher in areas likely to flood or have heavy snow.
Eric[/quote] Hello Eric. Thanks for your prompt reply. You are correct,that info came from part M of the building regs. which i got from a Hager site, brewtime.co.uk Product and Pics2447.pdf But how come that info from part M differs from 17th Edition? I'm confused. Regards
SD. :?:
