convert indoor pool to habitable space
pwe169
by pwe169 » Wed Jul 15, 2009 7:31 pm
Hi all,
I am converting an indoor pool in to an habitable space. the room is like an open plan bungalow attached to the rear of the house. I intend to go down the route of building notification as the main work I will be doing is covering the pool area, insulating the ceiling, walls and floor to bring the building inline with current regs.
I will be covering the pool with 220 x 50 C16 joists with 100mm overlap at each end fitting into notches cut in the old pool wall. Inbetween the joists I will fit 100mm celotex to give good insulation.
My problem is with conflicting advice around the pool edge. I have about 4 foot al round which is a concrete slab, 40mm screed topped with a 40mm thick 600mm square slab. One person says I can just cover this with my flooring material another says I need to get the old floor up but 75x50 battens down at the same centers as the pool joists, put celotex inbetween these and then cover. When I look at the info on the net it says that I need air circulation under the 75 x 50 joiists.
What should I do?
Pete
by stoneyboy » Fri Jul 17, 2009 8:17 pm
pwe169,
You certainly should cover the whole floor with an insulated layer, whether you need to ventilate under the floor will depend on whether there is a DPM under the existing floor. You will probably have to ventilate the pool area because this will not have a DPM incorporated.
