by matthewm1965 »
Tue Nov 18, 2008 10:50 am
I have just done a similar conversion.
I fitted a 2 port zone valve and small circ pump in the return pipe from the bottom of the cylinder coil.
When the tank stat calls for heat, it opens the valve, which in turn switches on the pump and and boiler signal.
This now heats up a cylinder full of water in 20 mins, then turns off the boiler. A big improvement on the old gravity system. It also prevents the DHW overheating when the CH is on continuously.
It is important not to restrict the vent / makeup section of pipework. In my case these were in the connection after the flow into the top of the cylinder coil. Which is why I put the control eqp into the return leg.
HTH
Matt
