danfoss TP 5000 Si programmer
waterman
by waterman » Sat May 08, 2010 11:12 am
hi can anyone tell me how to turn off my water based underfloor heating programmer for the summer,i dont want to shut it off at the mains fused spare switch,because i want to keep the display showing time and temp.it is a single room system and the programmer is a danfoss TP 5000 Si.I have the instruction booklet but it does not say how to do this,have also looked on net but no joy.thanks.
by sparx » Sun May 09, 2010 5:35 pm
Hi i would just turn down the room thermostat to say 5C so unless frosty won't come on.
by sparx » Sun May 09, 2010 5:44 pm
have just read up on this over complicated programmable room stat.
it does seem the only way to keep heating off is to set down the temp. as I said, however doesn't the boiler have a selector switch for hot water/ heating/both? sometimes marked summer/winter, just select no heating.
waterman
by waterman » Sun May 09, 2010 7:38 pm
hi sparx.
thanks for your reply,i will do as you suggest and just set down room temp to 5c.and i also agree with you it is a over complicated programmer.the one i have for my boiler is so simple with a off button/manual/auto.may look to changing it for a more user friendly model.thanks again.
