Post
by ALDA »
Wed Mar 12, 2008 7:56 pm
BB,
SYSTEM MAY JUST NEED BALANCING!!!
SPEED UP FLOW THROUGH RADS CLOSE TO BOILER AND SLOW FLOW THROUGH RADS FURTHEST FROM BOILER.
IF NO JOY, BOILER MIGHT NOT BE ABLE TO HANDLE LOTS OF DOUBLE RADS AND ASSOCIATED PIPE WORK!!!
IF YOU HAVE OR CAN GET BOILER INSTALLATION INSTRUCTIONS/MANUEL, THEN THIS WILL TELL YOU THE BOILER RATING AND FROM THAT YOU CAN ADD UP THE BTU VALUE OF EACH RAD TO SEE IF YOUR OVER THE MAX FOR THAT BOILER.
ALDA.
