Dodgey DIY Electrics?
misterg
by misterg » Sat Jun 30, 2007 10:38 pm
I was changing a socket in a bedroom that didn't work and noticed it was a spur in using 4mm cable instead of 2.5mm. The rest of the ring is 2.5 mm as far as I can see.
Is this dangerous, or did someone just have a bit of spare cable to use up?
The new socket works fine now, but just want to make sure it is safe.
G
poppedinsouldout
by poppedinsouldout » Sun Jul 01, 2007 2:42 pm
The thickness of cable used is stated by regulation, the regulations state 2.5mm is the [b]miniumum[/b] that should be used, so 4mm is fine. It does look like someone had a spare bit of wire.
Just make sure your ring circuit is on an MCB (minituare circuit breaker 32amp)
Hope this helps.
It is currently Sun Jan 12, 2025 4:28 am
