Dodgy push fit toilet sink waste
Dr Magyar
by Dr Magyar » Mon May 17, 2010 12:33 pm
I bought a property a while back and it has a small toilet room with a sink. Of and on it has had sewer gas smell which I recently traced to the waste of the small sink.
Lots of problems with the sink, like it was not installed level so that none of the plumbing fits properly.
Anyway, I also noticed that the waste is an embedded plastic push fit elbow, the small part of the elbow sticking out of the wall. Inside the elbow joint is a single rubber ring seal.
Is this normal? What is the best way to make this truely water tight and air tight?
I don't want to have to dig into the wall and start a major building operation.
by stoneyboy » Tue May 18, 2010 8:09 pm
Dr Magyar,
Separate the joint and use sanitary silicone sealant on the mating surfaces of the joint.
Dr Magyar
by Dr Magyar » Wed May 19, 2010 9:04 am
stoneyboy wrote:Dr Magyar,
I have read somewhere that although this might work in the short term, after a while sanitary silicone sealant will start to leak.
Is that true or an I unduly worried?
by stoneyboy » Thu May 20, 2010 9:07 pm
Dr Magyar,
Provided you apply the silicone to clean and dry surfaces there should not be a problem. If this is not successful you will have to dig out the elbow and replace it.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:49 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Sat Jan 11, 2025 12:43 am
