Double Flush WC Valve — Washer Replacement Part Number Needed
Nimrod
by Nimrod » Wed Oct 22, 2025 5:52 pm
I need to replace the washer on my WC double flush valve.
As you can see I have removed the cartridge successfully
I’ve look carefully but it’s not marked with the name of the manufacturer so I don’t know who to contact to order the correct replacement washer.
The OD of the washer is about 3”.
Also I wonder what the procedure is to replace the washer.
Does it unscrew? Do you prise it off somewhat like a bike road tyre?
Grateful to receive the advice and guidance from forum members.
Top view valve insitu.JPG (42.81 KiB) Viewed 192 times
Flush Valve Washer.JPG (21.02 KiB) Viewed 192 times
end view flush valve.jpg (29.66 KiB) Viewed 192 times
Double Flush Cartridge.JPG (24.01 KiB) Viewed 192 times
It is currently Sat Aug 01, 2026 9:51 am
