I recently drained down the h/w system and refilled it with and added a cleaning agent, with the idea to remove sludge build-up etc.
I took time to ensure that all of the radiators were bleed, started at the top and worked down – not sure if that’s the correct way round. I made sure that the system was fully filled before turning the boiler on again.
However, now only the heating works OK. The radiators all got hot, but for some reason there is no hot water. It appears that the when I set the boiler to hot water only, the boiler starts-up OK, but after about 1 or 2 mins, the boiler stops and appears to be very hot. I’m wondering if it is stopping as a result of any over-heat safety feature ?
Could there be an air lock somewhere in the system that could be preventing the water circulating around the boiler, causing the boiler to start over – heating and cut-out. As mentioned before, the central heating appears to be working fine.
Any pointers would be appreciated ?
Best Regards
Steve
