Draining down a Central Heating System
PatK
by PatK » Mon Jan 21, 2008 3:35 pm
I am due to drain down my central heating system (single piped system) soon and am not sure if I need to turn off the gas and electricity to the boiler.
I have read that you can just turn the thermostate control down to zero and switch off the timer. Other things I read say that the boiler needs to be switched off completely so I'm a bit confused.
Ideally I would prefer NOT to have to turn the boiler off (as I can't locate the electricity on/off switch!!). Will I damage it if I leave it on?
Many thanks in advance.
by htg engineer » Mon Jan 21, 2008 6:34 pm
There's no need to turn the gas off to the boiler.
As long as you can guarantee the boiler wont be turned on when it's empty then it wont be a problem.
Turning off at the timer and the boiler stat is adequate. Just make sure everyone in the house knows it's off, and they wont attempt to turn the boiler on.
