by htg engineer »
Mon Nov 01, 2010 5:28 pm
It depends on where the pipes feeding the radiators come from. If they come up from the floor - you need to drain below the floor. If the pipes drop down from upstairs, and there's no drain points then you need to turn radiator valves off and remove the radiator to drain.
htg
