Draining the Cold water Tank
10 posts   •   Page 1 of 1
dandan
by dandan » Fri May 01, 2009 2:02 pm
Hi ...I'm getting my asbestos water tank replaced with a plastic one and I've got to drian the tank...
I've not done this before - what steps should I go through?
cheers :?
Steve the gas
by Steve the gas » Sat May 02, 2009 5:16 am
Turn off the mains water feed to it and bucket it out
Hth
bd3cc
by bd3cc » Sat May 02, 2009 9:29 pm
If this is the storage tank that feeds the hot water cylinder, could you not close the mains feed to this tank, then open all the hot water taps on your system?
Steve??
rosebery
by rosebery » Sat May 02, 2009 10:50 pm
Turn off the cold feed and open a cold water tap in the bathroom.
steve the plumber
by steve the plumber » Mon May 04, 2009 11:05 pm
If the tank is asbestos then you should not be removing it.
rosebery
by rosebery » Mon May 04, 2009 11:20 pm
"If this is the storage tank that feeds the hot water cylinder, could you not close the mains feed to this tank, then open all the hot water taps on your system?"
No there is no point in emptying the HW cylinder and the CWST. Just drain the CWST via a cold tap that it feeds.
Dave From Leeds
by Dave From Leeds » Tue May 05, 2009 10:51 pm
To rosebery,
The CWST may not feed any cold taps. Mine doesn't - all my cold taps are mains fed. The CWST only feeds the hot water cylinder, so in this case bd3cc's response would be correct. In any case, turning off the mains and opening a hot tap would not drain the HW cylinder since the feed to the hot taps comes from the top of the cylinder. Once the CWST is empty, the hot tap will stop.
To dandan,
Steve the plumber is correct You shouldn't be removing the asbestos tank yourself due to the health hazards involved. It needs an expert in asbestos removal.
rosebery
by rosebery » Fri May 08, 2009 11:05 pm
@ Dave
Ok then so I made an assumption but so have you and so has bd3cc. If mines correct thats the simplest way and doesn't discard any hot water whatsoever which might be a consideration. You'll also note that I said in my second post "via a cold tap that it feeds".
As the OP hasn't come back again noone of us know which is correct.
In any event opening a hot tap won't drain the HW cylinder but it will EMPTY it of hot water the cold feed being at the bottom and the only way the CWST empties is to push all the hot out of the cylinder through the taps. Not that economically sensible.
And the OP didn't say he was removing the tank himself "I'm getting my asbestos tank replaced....." although what you say is one way of interpreting what he wrote.
In any event asbestos cement is only dangerous if it is drilled, cut or broken up. If the tank is in one piece its quite stable. If the thing will go through the roof hatch in one piece then there is no reason why he can't do the replacement himself. Even if it wouldn't he could still do the replacement and move it to an unused part of the roofspace, leave it be and worry about it at another time. No hazard.
Dave From Leeds
by Dave From Leeds » Sun May 10, 2009 1:23 am
rosebery, All fair points. Thanks. I wasn't trying to have a go at you, just putting a different angle on it.
dandan, Any news?
bd3cc
by bd3cc » Mon May 11, 2009 1:20 am
Agree my error, opening a hot tap would not empty the cold header tank, so should have suggested a cold tap.
The poster said that he was having the tank removed, which suggests to me that he is not doing the work himself, and from his other comments, is draining the system himself, presumably to make it cheaper, and less time consuming for the proffesional, who can then move on to another job.
It is currently Tue Mar 04, 2025 10:51 am
