Hi Folks,
First timer here so go easy on me!!
I have tried looking at past threads but have been unable to find an answer to my dilemma, so I apologise if this question has been asked in past.
Just recently had to change my ACL Lifestyle mid position valve as a result of the rads getting hot when HW only was called for, which was due to old age, crap in the system and port A not fully shutting off. The new valve I fitted is a Drayton MA1, like for like swap on size and wire colours.
Both CH & HW work fine now, however, when I create a demand – via room thermostat - for CH only the motor energises and moves to the CH position, when I turn off the room stat the motor does not return to the HW position and gets very hot after some time, it only returns if I create a demand for HW or if I remove all power to the system by turning off the fused switch.
It would appear that the valve is picking up some voltage form somewhere preventing it from resetting because of the internal switches not set correctly or the valve is knackered although I may be wrong.
Is this something anyone has experienced or come across? If so, what’s the solution as I don’t want to fork out unnecessarily if it’s something simple to fix.
All help and advice would be greatly received. Thanks in advance.
Oldschool BMX
