Expanding foam around wiring to fill hole
Pangloss83
by Pangloss83 » Fri Feb 12, 2021 4:51 pm
Hello,
I need to fill a whole in the wall where grey power cables lead into the extractor fan above our cooler. Can I use expanding foam to do this or is this a no around wiring? If the latter, what are the alternatives please? The whole is about 2 inches squared. Any advice greatly appreciated.
Many thanks
Oliver
Re: Expanding foam around wiring to fill hole
by stoneyboy » Fri Feb 12, 2021 10:10 pm
Hi pangloss83
Assuming the cables are only feeding an extractor there should be no issues with heat build-up if you foam fill the hole. You could move the cables to one side of the hole and then fill.
Hi pangloss83
Pangloss83
by Pangloss83 » Sun Feb 14, 2021 10:23 am
Hi Stoneyboy,
Thanks for clarifying this, much appreciated.
Best,
O
It is currently Wed May 14, 2025 3:23 am
