Post
by Skids »
Wed Mar 12, 2008 5:16 pm
Hi craddi1
That’s not a plumber !!! if you are talking about the Feed & Expansion tank (F&E), you MUST NOT fit or have any device to close the ‘primary return pipe, or the ‘open vent pipe’, from the Primary flow that loops up and exits above the F&E tank.
It all depends on the system you have:
If you have a ‘indirect single-feed’ system (an air bubble in the HWC) the HWC may/will have lost its air bubble, drain down the HWC and refill this will reinstate the air bubble.
You say it’s ‘fully pumped’, the problem will be overheating of the system, check the thermostats are working correctly.
you could also check the ‘motorised valves’ first (two or three port valves)
If it is your cold water storage cistern Greenhm is correct,
There are three pipes that connect to the cold water storage cistern (CWSC). One at the top that feeds the main water in, controlled by a ‘float operated valve’. The ‘open vent pipe’ that loops above the tank and comes from the boiler primary flow, this keeps the whole system at atmospheric pressure, and the one (possibly two) at the bottom of the CWSC which is the cold feed, going to cold taps and the hot water cylinder (HWC).
You turn on a hot tap and you get hot water, this draw off, draws cold water from the CWSC. As the CWSC is above the tap, the pressure (head) of the water is being pushed through the HWC to the tap. On its way the water is heated in the HWC, water expands by 4% when it is heated, (250lt HWC = 10lt). If you close the tap and close the valve fitted by the said plumber, you now have a pressure cylinder.
The safety aspects of the system are, if the thermostat fails to cut out the heat (immersion or boiler) the extra expanded hot water will flow back up the ‘cold feed pipe’ and into the CWSC, if the HWC boils the steam will exit up the ‘open vent pipe’.
If you or anyone else fits a valve to either the ‘open vent pipe’ or the ‘COLD FEED PIPE’ you have invented a bomb and when you turn on the heat the HWC will explode.
Check the immersion heater and as Greenhm said fit a safety cut-out thermostat.
Do NOT lower the water level at which the ball cock draws water in.
The problem will be overheating of the HWC,
Check the thermostat is set and or is working correctly?
If it is an immersion heater replace with a new high temp cut out thermostat with reset button
Ask the plumber for a refund after he has removed the valves, if you let him in!
Best of luck
Skids
