external tap plate has a gap
miyagisan
Post by miyagisan » Mon Aug 24, 2026 11:03 pm
so ive recently had an external tap installed and the builder hasn't done the cleanest of jobs, the brick got broken as he was drilling through the wall, and said this couldn't be avoided as he couldn't drill the other way and interally there was pipework.
anwya, the plate that is mounted, for two of the holes, the plugs go in where the brick is chipped. he's left the tap like this and i was wondering if the gap is anythign to worry about and if so, how to seal it. i'm worried that over time water might in and cause issues further down the line. ive had a quick discussion with chatgpt which suggested filling with tourpret and then putting some external waterproof sillicone, and wanted to check if this is the right advice? the builder originally said he'd come back and cement it, but i'm not sure he's going to return anytime soon. if i do fill it, is it best to remove the plate and fill, or just try to squeeze cement into the gap. from my experience of using cement, its not quite as flexible as fillers you can use interally.
Re: external tap plate has a gap
Post by Mr White » Tue Aug 25, 2026 1:20 pm
You can't "remove the plate" your tap is screwed into it (That is normal) I doubt you will get any cement in the gap, so I would suggest you use external use silicone since you can force it behind the plate and then run a bead all round the plate perimeter.
Make a note never to use a builder to do a plumbing job, and any decent tradesman would have come prepared.
miyagisan
Post by miyagisan » Tue Aug 25, 2026 5:56 pm
yes i think this is what i'll have to do. had a quick look to seek how these plates are put together and it seems like it comes attached to a copper tube, i was incorrectly assuming they were seperate.
many thanks for the advice :-)
It is currently Wed Oct 14, 2026 1:26 am
