Hi all, I need help figuring out the central heating/water system in my house. It's a 4-bed, 2 bath, built in 1910.
Downstairs at rear of house we have a combi boiler and expansion tank. Upstairs in an airing cupboard we have a hot water cylinder. In the loft there is a large tank which one plumber told me is not in use since I have a combi boiler.
We have a few ongoing problems but the first one I'm trying to tackle is; whenever we use the hot water continuously - run a bath or fill the sink. A loud vibration can be heard and felt coming from the loft tank or pipework going to/from it. The vibrations travel down to several of the radiators whether they are on or off.
Is it likely the loft tank IS still in use, and would this be hot or cold water? The noise appears to coincide with the hot water cylinder refilling, but sounds like it's coming from the loft tank.
I have a circuit breaker labelled "water heater" which I've had switched off for months now yet we still have hot water so I assume it is not related/defunct.
Anyone got any advice to what could be causing the noise/vibration and also if the loft tank is likely to still be in use and for what purpose? Thanks.
