Is it possible to get a flexible pipe that will fit a radiator valve? I can only find a 1/2" tap connector one, but am not sure if that is suitable as there is no olive. Is the only other solution to fit a radiator tail valve to the rad valve and then use a standard 15mm compression flexible pipe fitting? Reason I'm trying to avoid the tail is because I have limited room between the valve and the wall.
Background: I have a designer bathroom radiator cum towel rail. I was going to fit an angled TRV4 to it ( inverted, is that ok? ) and connect it with steel braided hose. ( I prefer the look and makes connecting much easier for me. )
Alan
