Fitting Honeywell DT90E in Place of old Dial Thermostat
M_arnold218
by M_arnold218 » Wed Oct 30, 2019 5:32 pm
I have a dial thermostat with the following 3 wires (according to the connections in it): N, L also looped through to COM, ON (and no wire in OFF).
I'm not sure how these should connect to the DT90E A,B,C connections.
Help appreciated.
Re: Fitting Honeywell DT90E in Place of old Dial Thermostat
by ericmark » Thu Oct 31, 2019 1:56 pm
http://www.free-instruction-manuals.com ... 457920.pdf
It seems A = Com
B = NO
C = NC
So you only use A and B so make the neutral safe, and other two go to A and B and really does not matter if wrong way around.
