Fitting new radiator brackets to a solid wall
clarkylad
by clarkylad » Sat Nov 29, 2008 10:44 am
Can somebody help me with this query please. I have taken an old ardiator off a wall and had the wall re plastered. I am going to get a new modern radiator to put back in its place of similar size etc. How do you calculate where and how high to mount the new brackets for the new radiator.
by htg engineer » Sun Nov 30, 2008 1:15 pm
Modern radiator ??? does it have a standard brackets ?
are you trying to fit to existing pipework/valves ?
htg
clarkylad
fitting a radiator on to a wall
by clarkylad » Sun Nov 30, 2008 3:45 pm
hi im sorry, im new to this type of thing. It will be a new single convector radiator with whatever brackets it comes with and will be fitted to existing pipework yes.
Apologies and thanks for your hel
by htg engineer » Sun Nov 30, 2008 8:38 pm
Measure from floor to center of rad valve, place bracket onto radiator, measure from center of tail hole to bottom of bracket.
+ the two = distance from floor to bottom of bracket.
htg
clarkylad
by clarkylad » Mon Dec 01, 2008 4:59 pm
Thanks very much, appreciate your assisitance
cheers
