Fixing Quarry Tiles and Bringing Them up to Desired Height
Coltheref
by Coltheref » Tue Apr 28, 2020 5:11 pm
I'm adding some 6mm thick quarry tiles to an area of low footfall floor that has been stripped and screeded with sand and cement. I need to bring the level up to the existing quarry tiles which are 15mm thick, so there is a depth of 9mm to make up. Can I do that with adhesive, or should I add another depth of screed say 4-5mm?
Approx. 1.5 sqm to cover
Re: Fixing Quarry Tiles and Bringing Them up to Desired Height
by stoneyboy » Wed Apr 29, 2020 10:53 pm
Hi coltheref
Suggest you use self-levelling compound preferably one including latex - an ordinary sand/cement mix is not very good for the thickness you have..
Coltheref
by Coltheref » Thu Apr 30, 2020 8:00 am
Many thanks, that's good advice, appreciate the feedback.
It is currently Mon Dec 30, 2024 6:49 pm
