I've recently had the front wall rebuilt with brick pillars either side at the front of the drive.
I want to fit double wooden gates but fit them directly to the brick pillars.
I plan to fit the gudgeon pin brackets directly to the brick using 75mm masonry screws avoiding the mortar.
The gates will be approx. 1250mm L by 900mm H with a simple frame and 2 internal cross braces.
Will this be strong enough and stable?
