I will be replacing the central heating system in a 5 storey Georgian House and the existing boiler flue uses the chimney. When replacing the boiler can I still run the new flue up the chimney. My CH system is located in the basement.
Also I have been tole that I have a commercial gas supply. Can someone advise why this would be the case and therefore should I use a commercial boiler which would provide greater heating capacity.
