Gas Hob
billobach181
Gas Hob
by billobach181 » Wed Aug 22, 2007 12:20 pm
Question: I have a Gas Hob sitting on top of a drawer unit. Is it allowed to connect the Hob to the gas supply by using a 1/2" cooker hose and bayonette fitting or must it be solid copper pipe.? A cooker hose would be less hassle for me after all you can connect a Gas Cooker by a bayonetted hose.
Regards
Bill Howells
by htg engineer » Thu Aug 23, 2007 5:37 pm
The gas hob will be ok installed using a rubber flexible hose and boyonet fitting. As it is to be fitted above a unit, not a oven.
A CORGI registered installer should fit it, don't fit one without testing for tightness and hope for the best.
This is not allowed if the hob is fitted above a oven, this is because the hose can crack and melt with the heat causing a dangerous sitiuation.
billobach181
by billobach181 » Fri Aug 24, 2007 10:20 am
Many thanks for you reply. It will be fitted by a corgi engineer but I can now get on with finishing the units.
Bll
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 11:15 am
It is currently Sun Jan 05, 2025 4:47 am
