by htg engineer »
Sat Mar 22, 2008 5:08 pm
You're heading in the wrong direction - the filter and the flow rate being reduced - is refering to the hot water i'm assuming this is ok ? if so the filter is fine. The filter stops any debri's getting from the mains cold water into the boiler.
Can you describe the combi fill ? is it fitted to the boiler ?
or a ballofix and a non-return valve connected with a flexi hose ?
take hose off - check there's no rubber washers stuck in either valve. Open the ballofix, is there water there ?
Could be a faulty non-return valve.
Hope this helps
